5 speed upgrade
andrewbishop66
First hi to all
not sure if this should be in the racing section or here so will try here first
I have been given an old pat hanlon road bike but the rear 5 speed block is worn on no 3 what is the maximum size i can replace it with (ie 7 speed) i dont wont to change the rear wheel so it will have to be a screw on block the distance between the frame is 120mm
any advice is welcome
Thanks andrew
tyred
Ireland
Any thread on freewheel will fit your hub but the spacing of the frame on your bike is for 5 speed. It would be necessary to spread the frame, re-space the axle (is it long enough?) to suit and probably re-dish the wheel to fit a 7 speed freewheel. The difference isn't that much in reality and a steel frame will "spring" wide enough but it will move the drop outs slightly out of parallel.
