Pale Rider
Neither of your matters of fact are matters of fact. Next!
OK, so by extension, a wound up, impatient driver is a safe driver?
Not so, in my view, but you are entitled to your opinion.
And from you I would learn exactly what?.....what the law is ? or how to consider other people before yourself?
Are you going to engage with any of the counter arguments put to you by people who rides bikes... a lot?Better make that 5...
To be fair, we don't know that. We only have one side of the story expressed as, shall we say, an unsympathetic rant?.... There are times to stand your ground and make your point, but that situation is not one of them.
Take a false premise and extend it? Keep digging!OK, so by extension, a wound up, impatient driver is a safe driver?
Do you always think you will prove your point by being nasty.I doubt you would learn anything from me.
I doubt you've learned anything from 52 years of driving.
Im a driver a motorcyclist..a pilot and a cyclist....not bad at decorating either
My point was (as stated) to think of other people. Your point seems to be .....be nasty and not consider other people.
Fine......enjoy your life.
BUT, cyclists say "Give as much room to overtake a cyclist as a car, use the next lane'. But with a car you're actually only giving it maybe 3 or 4ft of space in the next lane due to it's width.
For secondary position, this is half in the lane half out, and is the same space as has been given to the car?
And if you can't do that due to oncoming traffic or visibility then it's not a safe overtake anyway.
My point is that whatever 'gap' is left should be between the outermost cyclist and the car, so a car overtaking three cyclists needs to be further over. Here is some crude clip art. In one image there is room to get past. In the other there is not. The gap between the car and the outer rider is the same in both.But both require overtaking by moving into the next lane right (do the maths with the figures I mentioned above if you'd like to check), so there's no practical difference to motorists in giving three cyclists as much room as they should give a car, so what's your point?
That car is disproportionately wide so that misleads. Standard lane width is 3.65m and typical car width is about 2m, or about 1.5 cyclists abreast. If the lanes are wide enough for 3 cyclists abreast, the other lane is wide enough to overtake with plenty of room unless one drives like a dick.Here is some crude clip art. In one image there is room to get past. In the other there is not. The gap between the car and the outer rider is the same in both.
