A thread for classic motorcycle fans…
Cavalol
Chester
Yes, the brake and gears are the way you think. If I bag it, it'll be a learning curve for me too! The box behind contains a few spares, including a fuel tank, I'm going to have a closer look on Monday.
Good luck, lets us know how you get one, please. Fingers crossed!
Tail End Charlie
Well, write it down boy ......
And it's mine! Couple of minor things so far, a fuel leak and brake light sticks on but nothing major. That said, I haven't started it yet, there's a knack which I don't have.
@fritz katzenjammer I believe you had on older one like this, any tips? It has a decompression lever and I've looked on YouTube. It may be that it hasn't run for a bit so fresh petrol may do it.
Starting from cold: Fuel on, choke on, decompressor on, ignition off. Kick it through twice to get the juices flowing, a bit of throttle here may help. Next.. Decompressor off. Kick it through slowly until you feel compression. Ease it over top dead center. You can use the ammeter to find TDC, just watch for it to twitch which the points open. Let the kickstarter return to top. Ignition on, give it a whiff of throttle and kick through like you mean it. It should start first time every time once you get the knack. Once you are used to it this whole thing only takes a few seconds. You can turn the choke off pretty quickly on these things.
kick it like you mean it or it’ll kick you right back. That’s a 500 which came with a 6.5:1 piston… so it can’t kick back too hard.
starting from hot: no choke. Turn it over to find compression, watch for the ammeter twitch, ease it over compression, let the kickstart return, ignition on and a whiff of throttle, one nice smooth kick like you mean it and she’s running.
each one is different so you will need to figure out which little variation yours wants but it you follow the procedure / ritual these stupid things will start first time every time after sitting for months with stale fuel and a nearly dead battery. You’ll learn to love it for that alone.
don’t follow the ritual and you can kick away until you have a stroke and it’ll only give you the occasional fart.
wave a dead cat over it on tuesdays for extra karma.
these things came jetted very lean. If it hasn’t been done getting a slightly larger main jet makes a nice difference in engine performance across the board. I think your’s came with a 110 main jet and could do well with a 120. Oddly the gas mileage won’t change. My 350 got 90 to 95 mpg forever, it never varied. I think the 500 is good for 75 or 80 mpg.
whats the mileage on that lovely thing?
For encouragement… this is what they look like after 18 years and 76000 km. No idea what the inside of the motor looked like because it still ran like new when I sold it.
Cavalol
Chester
Congrats! Hopefully years of happy biking ahead.
Tail End Charlie
@fritz katzenjammer that is very helpful, thankyou. As you say getting to know the vagaries of the bike is part of the fun, but you've given me a good place to start. Good info about the main jet too. I've got to fix the fuel leak before I have real go at starting it.
The mileage reads 14500, which I think is right looking at the previous MOTs.
1960s Royal Enfield Crusader 250cc I wanted one of these so much in 1963 I would stop off on my way home from work and drool on the dealers showroom window.
Neat little bikes. Except they stuffed a five speed gearbox into the space for the old four speed making for a rather fragile package. I still want one though.
however… since I couldn’t have that, I put this together. My last bike before retiring from a life long sport. Traffic is too stupid to be survivable now so it was sold on back in the spring.
*sigh*
dicko
Derbyshire
*sigh*
The Suzuki 250 single is still today a bullet proof engine parts everywhere mechanics dream to fix.
Actual, what made those engines so great was that you never did have to fix them.
unlike my Kawasaki Ninja, which went through its buttery soft cams faster then it went through tires or brake pads.
No kidding, what a turd.
and then there was…
Tail End Charlie
Been doing some work on my Royal Enfield. The fuel pipe was brittle and had split so I replaced that and found a load of crud inside the petrol tank. Replaced the fuel cock and also cleaned out the tank and sealed it with POR15, I enjoyed that process. In essence the tank has to be cleaned, dried then etch primer used, then dried and then the sealer goes in. The process takes all day and the sealer needs 4 days to harden properly. Several of the rubber parts between the carb, air filter etc had split so I have replaced them too.
I then tried firing it up, it did go but revved very highly (some muppet hadn't put the carb back together correctly :whistle:). After that the compression was right down (about 55 psi instead of 110).
I've taken the head off and will regrind the valves (annoyingly my valve spring compressor doesn't fit, so I've ordered a different type) and will also replace the piston rings (had to get a gudgeon pin remover aswell!). Also annoyingly you can't remove the barrel whilst the engine is in the frame, so I've tied it up.
As you can see there is oil burned onto the piston, I'll clean that up and will fit some new rings and hopefully the lack of compression will be solved. Even more hopefully it might actually start!
Tail End Charlie
Been beavering away on my Royal Enfield. Whilst I had the barrel off I took advice from the owners forum and replaced the stock piston with a very shiney (and spendy!) forged piston, it is actually UK made. It also raises the compression from 6.5:1 to 8.5:1.
Continuing with the theme of spending, I replaced both valves with upgraded ones and had the valve seats recut. (I did start the strip down because of poor compression). The valve seats were recut at a great little engineering place in Stockport - Quantum Engineering. Not a computer in sight, just a few middle aged guys doing things by hand. Places like these won't exist in the future.
Started the rebuild. I had found that I could remove the barrel with the engine still in the frame by removing one of the cylinder head studs. New gaskets, washers etc. re-fitting the gudgeon pins was a bit fiddly, or maybe I just don't have the knack.
Once put together I tried starting her. After a few attempts over several days, I did get her going by "force" starting (i.e. heating up the spark plug and using easystart). What a feeling when she fired up! I wasn't expecting it really! Went up and down my drive a couple of times, first and second gears engage and she sounds great (I have since lowered the tickover speed). Best Xmas present for me. I would post the video as it sounds great, but computer says no. Roll on spring when I'll tax and insure her!
Since then I've been fiddling with the electrics, removing some gubbins the previous had put on.
