Profpointy
Been beavering away on my Royal Enfield. Whilst I had the barrel off I took advice from the owners forum and replaced the stock piston with a very shiney (and spendy!) forged piston, it is actually UK made. It also raises the compression from 6.5:1 to 8.5:1.
Continuing with the theme of spending, I replaced both valves with upgraded ones and had the valve seats recut. (I did start the strip down because of poor compression). The valve seats were recut at a great little engineering place in Stockport - Quantum Engineering. Not a computer in sight, just a few middle aged guys doing things by hand. Places like these won't exist in the future.
Started the rebuild. I had found that I could remove the barrel with the engine still in the frame by removing one of the cylinder head studs. New gaskets, washers etc. re-fitting the gudgeon pins was a bit fiddly, or maybe I just don't have the knack.
Once put together I tried starting her. After a few attempts over several days, I did get her going by "force" starting (i.e. heating up the spark plug and using easystart). What a feeling when she fired up! I wasn't expecting it really! Went up and down my drive a couple of times, first and second gears engage and she sounds great (I have since lowered the tickover speed). Best Xmas present for me. I would post the video as it sounds great, but computer says no. Roll on spring when I'll tax and insure her!
Since then I've been fiddling with the electrics, removing some gubbins the previous had put on.
My first thought was that that was a Burnurd collet chuck for a lathe like this one
