Aaargh! Does not compute! Brain Teaser
nickyboy
Norven Mankey
Im estimating logic, not trying to create hard rules so, if 76 is needed after the last divisor, 76 is likely to be the result of 19x4, 38x2 or 152/2 hence H/I as 1,2,4,8 combinations
Working on the assumption of one of the first two, working back A and B need to result in a low number, because 12 is added and then multiplied (multiplier must be low, probably 3).
Methinks it's a combination of your fuzzy logic and my hard rules that will prove to be the winning combination.
Hopefully I get a dull spell of play this afternoon so I can give it some thought
Tin Pot
8hrs solid of meetings.
Maybe on the train home ill get a few minutes.
7
+13 =20
20 x 1 = 20
20 / 4 = 5
5 + 9 = 14
14 + 12 = 26
26 x 2 = 52
52 - 8 = 44
44 - 11 = 33
33 + 5 = 38
38 x 6 = 228
228 / 3 = 76
76 - 10 = 66
Congratulations you have won a picture of Rachel Riley or the Vorderman!
Was it through trial and error or proper maths tho?;)
Asa Post
Super Iconic Legend
Sheffield
A mixture of both. It's very likely that certain integers won't be in certain positions. That narrows down the options. Then I worked out a possible relationship between the last two integers and tried some variations on the assumption the relationship was correct. It was. Is that luck, or skill?
I'll take Carol over Rachel.
