About turbo trainers...
KneesUp
I've decided that a turbo would suit me, so I've started to look into them, starting from a base of pretty much zero (my uncle used to have one in the dining room and I remember going on it as a kid. Apart from that I know nothing)
So far I've discovered
1) Magnetic ones can be noisy - how noisy, though? If I use it indoors it will have to be in the kitchen, below the kid's bedroom. Is it 'wake a child from the floor below' loud? Or annoy the OH in the front room loud?
2) Fluid ones are more expensive but quieter - how quiet?
3) Fluid ones (the cheaper ones, anyway) don't have a resistance adjustment as such, they just get harder the faster the wheel goes - so I suppose if you want lots of resistance but not to be pedalling like a fixed wheel going off a cliff you just change gear on the bike?
4) There are a lot of software options. I think I would like to use Golden Cheetah because
a) it's free
b) I use Linux
c) It looks packed full of information. I love a spreadsheet
I *think* I can get Golden Cheetah to talk to the bike if I fit it with a cadence sensor and speed sensor on the rear wheel (I believe the rear wheel sensor will give the best proxy for power without buying a power meter?) and get a chest strap hear monitor thing? Any advice here much appreciated, with turbos in general and with Golden Cheetah specifically.
The ones that adjust resistance automatically according to the training plan look excellent, but a but pricey - and also magnetic at any reasonable price, so I'd have the issue of noise (or I could use it outside, but then if it runs of the mains that will be an issue if it's raining!) On this basis I think I'm currently looking at a s/h fluid trainer to see how I get on, but as I say, I'm probably missing something, so any input would be much appreciated. I'm not aiming to 'compete' - I just want to get fitter!
S-Express
Mag turbos are not noisy. Where did you discover that they were?
KneesUp
KneesUp
S-Express
I've seen it mentioned loads of places when I've been doing research - this is typical
Noise
Perhaps the least attractive aspect of a turbo trainer is the noise they make. It can sound like a plane taking off and that can pose problems if you live in close proximity to your neighbours. - http://road.cc/content/buyers-guide/217308-16-best-turbo-trainers-and-rollers-—-smart-and-traditional-home-trainers
Can't see anywhere in that link where mag trainers are specifically referred to as 'noisy'. Either way, the only noise from a mag turbo will be from the tyre/roller interface, ie same as any other turbo. Fan trainers are obviously noisy, but mag trainers - because of how magnets work - are not noisy, by definition.
Mag turbos are very quiet. Especially compared to the old 'turbo fan' ones. You can hear laptop speakers over a mag turbo. I have a Tacx Smart turbo as it does give you compatibility with Zwift, bkool, trainer road and others.
I would also recommend to use the turbo somewhere cool with fan(s).
Keep an eye out on sales as I managed to get my turbo with over £60 off.
KneesUp
KneesUp
Fluid trainers are noticeably quieter than magnetic trainers, which is especially important for apartment dwellers. - http://www.livestrong.com/article/342113-fluid-vs-magnetic-bike-trainers/
As far as noise levels are concerned, magnetic turbo trainers sit somewhere between loud wind trainers and almost silent fluid trainers. - http://biketrainer.reviews/magnetic-resistance-trainers-guide/
One issue is that the system heats up and therefore most mag trainers use an additional fan to help cool things down. This can generate a fair amount of noise, so mag trainers can be quiet noisy. - http://turbobiketrainer.com/magnetic-indoor-turbo-trainers/
That sort of thing - as I say I'm new to all this; the impression I've got reading around is that mag ones are noisier than fluid ones, and some are quite loud.
As someone who has used a 'turbo' fan, a simple adjustable resistance mag trainer and a smart mag trainer, the noise you get from the mag trainers is minimal. Gears, tyre noise, heavy breathing are louder. That's from experience and not articles. I use mine in the garage as I have the space - the house would be too hot. The mag trainers just get warm.
Turbo fan trainers will drown out the radio.
S-Express
It's simply not true that mag trainers make more noise than fluid. As I said before, assuming both use a roller, the noise issue will be about the same. If the trainer uses a fan for any reason, then the fan will create noise. Many mag trainers (such as models from Tacx or Minoura and probably others) do not use fans, so therefore create no extra noise.
I have two mag trainers - a Tacx Bluematic and a Minoura V130 and both are extremely quiet. The only noise comes from the tyre on the roller.
Have another read. The same article also says that mag trainers can be as quiet as fluid.
CanucksTraveller
Hertfordshire
Hi @KneesUp
My research found the same as you, that mag trainers were generally regarded as "a bit noisy". That worried me too, particularly as my daughter sleeps upstairs and I didn't want to be banished to the cold garage, so I understand your feeling.
I've got the TACX BlueMatic Smart which is magnetic. If I'm on it, I can certainly ride it with no complaints from my wife watching telly in the adjoining lounge. Similarly, she can ride it while I'm working (no telly on) in the lounge, and all I can hear is a low level hum. Most of that is tyre noise I suspect. My daughter's not been woken up up by it yet. So yes they create a little bit of low frequency noise and vibration, but it's not loud or excessive and I don't think it'll bother anyone in your house.
KneesUp
KneesUp
That's what I'm after :smile:
Now this may well be a totally daft question, but can you keep them outdoors? I can't see why a fluid one would be bothered by being outside, although I can see why a mag one might not be sealed and therefore the internals could get water in, which might be an issue. I don't have a garage or shed I can use, but there is some space out the back of the house that is concreted, so I could use it there.
I wouldn't keep them outdoors, but you can use them outdoors. You could use it in the kitchen with windows or doors open. You will need a fan though, and an electrical supply if using a smart trainer. If you don't have space indoors to store one, then I'd maybe get a garden storage unit. They aren't sealed units so you'd not want rain getting in the mechanicals.
CanucksTraveller
Hertfordshire
I'd store it indoors and carry it outside, much as that's a bit of a minor faff, at least it's only an extra 5 minutes to set up. I can't see a mag trainer doing well out in the elements.
S-Express
The fluid resistance unit will not be affected by the weather - but then neither will a few magnets. It's the roller drums, bearings and frame pivots you need to worry about.
KneesUp
KneesUp
I was avoiding a 'smart' trainer for this reason. Also because I don't really know if I'll get on with it, so I'm getting a cheap one first. Perhaps if I have a garage one dat I'll get a 'smart' one. I think I'm right in saying that some transmitters fitted to the bike frame and an HR monitor on me will send useable data to Golden Cheetah - which might not be very well callibrated, but will at least be consistent.
