Tom B
- Lancashire
I have stock Tekto HDC-300s fitted to my bike... They are two piston Hydraulic jobbies
The rears are behaving like they need adjusting for pad wear. Sitting cold i can squeeze the handle down to the bar grip with some effort. Admittedly this is well past lock-out point but still i prefer a bit point nearer the top of the lever. When the brakes have been rubbing and all is hot, it seems a little worse.
There appears plenty of pad left.
I have never fiddled with hydraulics and on the face of it there does not seem any way of adjusting the pads out.
On cable operated disks i would have slackened off the slides and wound the pads out and then tightened. Thee does not seem an option for this.
It does seem on the face of it that both pistons move out and can be retracted and thus the pistons would take up the wear of the pads
Am I being a dunce and missing something or is this just likely to be the pipes swelling under pressure?
The bike is pretty new so is still in the bedding down stages - i just hope it doesnt bed down much more!
