Night Train
Maker of Things
- Greater Manchester
This is the sort of starting point I would use.my speciality .
ideally 1 socket for each appliance so if you have games consoles DVD Sky etc by the TV you want at least 3 twin sockets behind the TV.
kitchen sockets are hard to decide without seeing a basic plan but we have 5 twin sockets in a galley kitchen and i wish I had put in more
minimum I would wire on a rewire is
1 ring for kitchen general sockets
1 ring for kitchen white goods
1 ring for downstairs
1 ring upstairs
1 lighting circuit down
1 lighting circuit up
Central heating
immersion
Cooker
get a smoke detector circuit wired at same time and get lithium battery interconnected smoke alarms. will put about £200 on the price
split dual RCD board
IET have a guide in the onsite guide and if you PM me an email address i can get the info to you.
MAKE SURE THE GUY IS PART P REGISTERED. as much as i hate advising you to as it is part of building regulations.
I'd add a third lighting circuit for the hall, stairs and other non room areas. Also one for any external lighting if needed.
Another point is this.
I used to install a whole load of sockets behind the TV area. I don't any more. All the entertainment equipment, if it is used in the same place doesn't draw that much current. If there isn't too much of it then I would have an extension lead fitted to the back of the TV cabinet and then everything plugs into that. The lead then plugs into one wall socket. I do likewise for computer workstations as it makes it easy to switch everything off in one go.
In my kitchen I have two double sockets per meter of work top in addition to switched circuits for the appliances and a lighting circuit for the under unit lighting.
In rooms in general I have a socket in each corner and in the middle of long walls but placed to suit furniture placement. The bedroom, for example, has two sockets on the bedhead wall, one on each side of the bed.
Don't forget local and task lighting for the bike repair area and a couple of sockets for the power tool charging.
If you have a driveway or garage then maybe a vehicle charging point, or at least a conduit for ease of later installation.
. personally i think a ring in domestics is far better. commercial installs then radials definitley.
emf is electromotive force , what you are concerned about is Electromagnetic compatibility
