alci4
- birmingham
hi folks i am looking at getting a new bike but was wondering which is the better spec from the 2 bikes below
will be using for on roads, canal towpaths and light trails but would like to move in to more rugged as i get more xp.
thanks for any advice you can offer
they are both £399.99
the first is
GT Aggressor XC 2 Mountain Bike 09 20"
Carrera Kraken 20" Mountain Bike 09
the first is
- Frame Material: Aluminium
- Frame Size: 19-20
- Gender: Mens
- Suspension: Front
- Alloy Rims: Yes
- Brake Type: Hydraulic Disc
- Chainset: Truvativ Isoflow chainset with sealed Bearing BB
- Exact Frame Size: 20"
- Forks: Suntour XCR fork, 120mm travel, rebound damping & lock-out
- Frame Colour: Black and White
- Frame-: Lightweight hydro-formed aluminium Triple Triangle frame
- Front Brake: Tektro Auriga Comp hydraulic disc brakes, 180rotors
- Front Mech: Shimano Deore
- Gear Shifters: Shimano Deore Rapid Fire
- Handle Bars: GT oversize
- Headset: GT Alloy
- Hubs: Formula DC 20
- Number of Gears: 27
- Pedals: Classic Cage with Toe Clips
- Quick Release Wheels: Yes
- Rear Brake: Tektro Auriga Comp hydraulic disc brakes, 160rotors
- Rear Mech: Shimano Deore
- Rear Shock: NA
- Rims: Alex ASD-1 disc rims
- Saddle: SDG Bel Air saddle
- Seatpost: Alloy Black
- Stem: GT Oversized
- Tyre size: 2.3"
- Tyres: Maxxis Ignitor
- Wheel size: 26"
- Approximate Weight (KG): 12.7
- Alloy Rims: Yes
- Approximate Weight (KG): 13.64
- Chainset: Truvativ Isoflow with Power Spline BB
- Fork Lock-out : Yes
- Fork travel: 120mm
- Forks: Suntour XCR 120mm Travel
- Forks - Adjustable damping : Yes
- Frame Colour: Grey
- Frame Size: 20+
- Frame-: 7005 Aluminium
- Front Mech: SRAM X5
- Gear Shifters: SRAM X5 27 Speed Trigger
- Gender: Mens
- Handle Bars: Kalloy Alloy 31.8MM
- Headset: Semi Integrated
- Hubs: Fomula Alloy Black
- Pedals: Wellgo Alloy Black
- Rear Mech: SRAM X5
- Rims: Double Wall Alloy
- Saddle: Carrera
- Seatpost: Kalloy Alloy 31.6MM
- Stem: Kalloy Alloy 31.8MM
- Suspension: Front
- Tyre size: 26 x 2.3
- Tyres: Continental Speed King
- Wheel size: 26
