arallsopp
Post of The Year 2009 winner
- Bromley, Kent
Lots of good replies already, but here's my tuppenceworth.
if you stop in the wrong gear it's much more difficult - even impossible - to start off again because you can't get out of the saddle and heave on the pedals...get
If you get the hang of unclipping with your left foot, you'll find you can use your right heel to derail the chain from the big ring onto the middle ring by pedalling backwards and timing your kick. It works when stopped at lights, and takes about 2 secs to pull off neatly. Don't forget to shift down on the front just after you see the chain hop, so that it doesn't rub the cage and get hung up.
I do this less nowadays, as I'm getting better at anticipating things. I've tried filming it (as its hell to describe) but my cam doesn't go wide enough to show it clearly. Maybe a job for the wife
Andy.
