After how many miles should you replace your tyres?
Welsh wheels
Lycra king
South Wales
My current set of Kenda Kriteriums are starting to rack up some serious mileage, they've done over 1500 miles now. I was checking them yesterday and I can't see any visible signs of wear but I was wondering is there a point at which you should replace your tyres even if they don't appear worn?
Heigue'r
Upminster
I got 1400 miles out of a set of pr3 giant tyres and then it was like they fell off a cliff...flatted out pretty rapidly and started getting punctures every few days having had none in 1400 miles.Some tyres have an indicator on them...when this is gone,time for new
Welsh wheels
Welsh wheels
Lycra king
South Wales
Having said that although I can't see any wear on the surface of the tyre, there are two strange line/cracks on the bottom of the sidewalls, one on each tyre. I can't tell if they are wear or something else. I have attached a picture, hopefully someone will be able to help me identity what they are.
Welsh wheels
Welsh wheels
Lycra king
South Wales
Thats a crack, and it needs binning.
Thanks, good to know
KnackeredBike
I do my own stunts
[QUOTE 4939216, member: 9609"]as long as you renew the air in them every 465 miles they should be fine. (remember to renew the air on a dry day, no point in having heavy damp air in your tyres)[/QUOTE]
I wouldn't say a dry day because it will shorten the life of your inner tubes. Ideally you want very cold damp so as not to rust the valves, I do it about 6am on a frosty morning but of course if you can't make the effort to do it properly within a few paces of an open freezer door is probably sufficient as well.
pclay
Rugby
Schwalbe Durano are generally good for about 5000 miles. You cannot tell if a tyre needs replacing based on mileage, as this will depend on the tyre.
In general, a tyre will need replacing if:
1, you start to get frequent punctures and/or
2, the tyre is visibly worn (the threads are showing through) and/or
3, the tyre is damaged and/or
4, the wear indicators have gone.
