I'd be amazed if it didn't. Do you know the size of the rims by any chance?
It has Mavic CXP22 rims Potsy.I'd be amazed if it didn't. Do you know the size of the rims by any chance?
Can I ask why you want to change?
Thanks FF. Measuring the width available with a steel rule seemed to show that 25c's could be accomodated, but I wondered if under load the tyre would deform beyond that.I think it's more to do with clearances between the frame and tyres than the rim size, though 25c is not a huge tyre and becoming more common for everyday and even club/training bikes.
I wanted to increase comfort Paul.
From my experience you wont notice any real difference in comfort, certinly not enough to buy an new set of tyres for.
You might want to try a softer saddle and/ or some gel pads under the bar tape. I think there is a saddle for free on the classified section that might be a bit more squidgey.
http://www.cyclechat...comfort-saddle/
If it's a comfort thing why not run with slightly lower tyre pressures?
An Allez running on fully pumped up 23mm tyres is not exactly built for comfort Wardy.
What psi do you run the tyres at now?
Do you wear padded gloves and padded shorts?
If you do then it might be an idea as others have said to drop the psi a bit, I run mine at around 120 but am sure they'd be fine at 110, or even 100.
If that doesn't work then maybe go up to 25's but try the air pressure 1st as it's free!!
don't buy 25mm tyres!
if you want to increase comfort you'll not achieve it by adding 2mm to your tyre width
try a different pressure - 85-90psi
otherwise, just get used to it. I know on heavily pot-holed roads it can be a real pain on a road bike but nothing will cure this except a new road surface or a full sus MTB.
