bonsaibilly
That'll be the diesel fumes making you light-headed and giving you an asphyxiation high.![]()
It'll be the additives.
Wear a pollution mask.
When i was a courier riding 10 hours a day in London i wore it only on the busy streets.
In the 1990's pollution was worse as the diesel engine's then belched out much more smoke.
After a days riding with the mask, when i took it off the part of my face that wasn't covered by it was dirtier than the part that was.
When i left London after 11 years of cycling there i moved to the country side, i coughed up loads of stuff from my lungs with black spots on it and my wife used to comment that i smelt of metal, i could smell it too, chemicals from the pollution no doubt.
There are face masks that will filter the particles out.Probably the Lead. It's virtually non-problematic now. FYI face masks are not effective against micro particulates that cause the problems with disel fumes. They pass right through.
I recall seeing a Top Gear episode where they tested the amount of fume levels people inhaled in London either in a car, as a pedestrian, on public transport or cycling (I know it had car and cycles). Cycling came out lower than car driving interestingly which I believe they accredited it to being sat behind lorries and busses with the AC on sucking in the fumes. Not sure if that episode is still on iPlayer but it had interesting results none the less.
I believe independent scientists more than I believe a Toyota fan site.I simply don't believe that the air in a car equipped with a carbon activated filter is more polluted than the air outside the vehicle.
http://www.tundraheadquarters.com/b...abin-air-filters-do-they-live-up-to-the-hype/
I would agree with that.I believe independent scientists more than I believe a Toyota fan site.
Or the ones I mentioned earlier at https://www.cyclechat.net/posts/4829639 - no idea why there was a temporary downgrade to Top Gear.
Eight pagesOr the ones I mentioned earlier at https://www.cyclechat.net/posts/4829639 - no idea why there was a temporary downgrade to Top Gear.
I'll stick with what's quoted.Eight pagesI'll stick with what's quoted.
Either way, it's irrelevant as the OP is going to use the train.
And it's also irrelevant because - again - there are more than one fairly direct routes between Kingston and Chiswick that are almost entirely away from heavy traffic.
