Already in use, in trainers to charge your mobile device.
Ok this is just an idea, I was considering ways of storing power in a bicycle to provide a boost when you need it - without using an engine.
one way I thought was using momentum.
I have seen how if you put a weight on the outside of a wheel you can make the wheel spin longer as the momentum in the weight carries on after the power has stopped.
now imagine a tube on your wheel , in it is a stop and a weight , as the wheel spins the stop carries the weight around inside the tube, and so the weight is carried at the speed of the wheel, now if the wheel slows down , the weight carries on around the the tube till it hits the stop and then the force of the weight drivers the wheel on.
so thats the theory , whats the maths , well I,ve got 1lb weight at 15mph produces 24.5joules
so if you have it both wheels thats nearly 50 joules of energy driving the wheels round.
I admit I have a fairly shaky grasp of physics (as anyone who knows me will agree) but it seams to work in theory. - I think.
Wouldn't work: Microsoft have probably patented the term "bing"You're just overcomplicating things...
What you need is a bing spring that you can connect to pedals or bike at will. Thus, along the flat you can divert effort to wind up the clockwork, then when you need an extra spurt on, you engage "clockwork boost". You could wind up the spring with the bike stationary at home whilst you are watching telly - and use this stored energy on next day's commute....
.....but don't tell anyone - I'm off to the patent office tomorrow
What is wrong pushing the pedals with your legs? Pour porridge down your neck and push the pedals!
2 strokes can be made very quiet, in fact one of the issues is that an E-car and bike needs to havea bit of noise so others know they are there.I'm actually with you on this, I'm just looking for the most effecient use of the power available. - although I 'm all for electric bikes rather than the 2stroke lawnmowers kids scream around on - (scream as in noise not speed)
some great stuff so far , the flywheel is a definate yes in any design I'm working on. mostly to tackle hills and to get into the higher gears on 200tooth chain rings. - (the design on the super bike has got to sponser required stage as prototypes are horribly expensive, just checking pattents is £500+ ) so at present it only exists on paper
