Fiona N
I don't usually have much problem tracking down 'noises' on the bike but this one has me perplexed.
The story so far:
I just started riding upright again this Spring after a long period of back injury (and recumbent riding) and got an old steel-framed Chas Roberts out of the loft where it had been lashed to the turbo for the last four years. Lovely to be riding a nippy roadster after only a mtb on the road. But alarming cracks on the under side of the down tube just behind the headtube suggested that all was not well so I bought a Al+carbon seat stays frame & forks from Ribble thinking to swop the parts over and make a winter hack bike.
This involved a bit more than just swopping parts as the new frame had a hidden Ahead headset and threadless fork so needed a new stem. Also the frame tubes are bigger so I also needed a new band-on front derailleur (Tiagra) and a new seat post (carbon). The rest of the gear is basically Shimano 105 with a triple chainset.
From the first rides, there was a lot of noise which sounded like the chain rubbing on the front derailleur. So I fiddled and fettled but couldn't get rid of the noise. Plus it seemed like the chain was entirely clear of the derailleur cage when the noise was heard. Then I realised that the noise didn't occur if I pedalled gently - really smooth spinning along and all's quiet. So then I thought, it's the stem/bars when I pull/push on them when pedalling harder - but no, I can ride hands-free and the noise is still there. Likewise, it occurs when I'm out of the saddle so seat-post seems not to be involved.
The noise is most noticeable at the point when the pedals are most loaded, just after 12'o'clock and tends to diminish about the 'neutral' point. It occurs in all three rings but I've checked the chainring bolts anyway as well as the pedals (Crank Bros Quattros). It's definitely worse (loudest and most 'crunchy' sounding) when I'm cranking up a hill out of the saddle.
About the only thing left is the bottom bracket and the LBS has a new one on order for me but I was wondering if anyone had any experiences (e.g. with Ribble Al+C frames) which might shed light. I'm afraid I'm one of those perfectionists whose bike ride is spoilt by any untoward noises coming from the bike.
The story so far:
