Any leg strength exercises for people with arm in a sling
ColinJ
Puzzle game procrastinator!
Do a long walk very briskly, including up some hills?
Exercise bike worked for me after shoulder surgery, although I didn't use the sling, I could rest against it.
And +1 to walking, I did lots as I wasn't permitted to drive for 8 weeks or cycle for 12.
Is your arm to be in a sling for the whole 6 weeks or just as needed for support or protection. If the former, get yourself set up with a good physio to work with after as your arm and shoulder will be as weak as a kitten and stiff as a board! Mine is my dominant arm which is probably worse still
Stonechat
Stonechat
Not currently a gym member. When still working, used gym at work. I had intended to start this winter. My idea was leg strength mainly. This injury has made me think I can at least do something while off the bike
I walk the dog twice a day, so at least getting that in
Take the dog somewhere hilly to work your muscles more, might be hard around Staines though!
Join a gym, you'll appreciate the machines for rehab, although not for a number of months (if it's a shoulder)
Stonechat
Stonechat
Trouble is not driving. Being a cyclist I know all the hills.And Mrs S will take me places within reason, but not worth it for rotine dog walks.
there are a couple of gyms, Staines centre at Staines FC and Council Leisure Centre both walkable
Sounds like a plan. Just join one with a minimum contract length or no notice period. I pay £18 a month for mine
You can ramp up the slope on the treadmill for a bit more of a workout
Check with the Physio what's advisable. Did you have / are having surgery? If so also check with the surgeon
Let pain be your guide
S-Express
Dog walking or hill walking is not going to give you any increase in leg 'strength' though, although it will help with general fitness. Is it fitness you are after, or leg strength specifically?
ColinJ
I had made the assumption that it was actually a subsitute for cycling, and therefore fitness, but I now think that Stonechat actually did mean 'strength'.
I am not sure why anybody trains for strength since lack of leg strength is rarely a problem on or off the bike.
As for a lack of local hills ... use stairs as a substitute. For extra 'strength' training wear a rucksack filled with something heavy!
You can use a turbo or do one legged squats which will be excellent for stabilising muscle groups as well. In fact you might find you can't do a one legged squat without holding something. You don't need to go too far down with a squat and you need to keep feet and knees in line so do look up the correct technique before you try.
I don't think carrying a heavy rucksack following presumably shoulder or arm surgery while wearing a sling would be advised by a surgeon or Physio :smile:
Edit...posts by @Stonechat suggest sling is to allow a broken upper humerus to heal. Ouch
Dogtrousers
Kilometre nibbler
The problem is, so many bits of the body are all work in concert* and you may discover that your arm is really needed in all sorts of exercises, even ones that you wouldn't expect. So it's a bit suck-it-and-see.
I found this when trying to recover strength in my leg after an operation, and having my leg in a brace for a prolonged period, while also having a damaged shoulder.
*For a technical analysis of this, see https://en.wikipedia.org/wiki/Dem_Bones
