Electric_Andy
Heavy Metal Fan
- Plymouth
I'd like some feedback from anyone who is interested please. it's a bit of a story and some things are probably conincidental:
My son has a 2022 Peugeot Kisbee 50 GT (that's what the V5 says anyway). It had been running fine but he stopped riding it for personal reasons, so I took it out last week to blow some cobwebs out. I got 5 miles out of town and it conked out; symptoms were identical to running out of fuel (but it had 3/4 of a tank). I parked up, phoned my partner, wondered how I'd get home, and then thought I'd try starting it. it started up fine and I rode home fine. I noticed that the headlight (dipped beam) was blown so ordered another bulb.
I've had it on the trickle charger and last night changed the bulb, and it come on and then went out. I don't know if it's blown again or if the battery is dead. I now have no ignition lights at all. My trickle charger is also acting up (it's showing both red light for "battery dead / problems" and green light for "all is fine, battery tender mode). So I've ordered a new trickle charger.
I suspect that it may be the regulator/rectifier, as this is what happened on my old FZ6 Fazer. So my plan is:
Put battery on new trickle charger to check battery health - it may have been toasted.
Check fuses with multi-meter
Check contact/earth points for corrosion
Locate reg/rec and test with multi-meter, order new one if needed.
Does this sound like a sensible plan?
