GrasB
- Nr Cambridge
A friend has a mid-range Ibiza & it failed its first MOT on brake balance. The garage kind of sorted it, looks like they dropped in new discs & pads, to get it passed the MOT but it still wasn't spot on & got an advisory. I got handed the car & sorted the problem properly, a partial strip down of the callipers revealed a dodgy dust seal was causing one of the pads to twist & stick on when hot causing excessive wear. With a second new set of pads off I go to bed them in properly & what a shock I was in for...
At the 20-5mph set the brakes felt strong enough & improved on every application, maybe a little too sharp at the end of the process but I'm no used to heavy servo assistance. More importantly there was no pull on the brakes at all, even almost completely letting go of the steering wheel the car stopped straight as a die. Time for the 40-5mph set was okay, good initial bite again I felt it was a little too sharp but the power felt okay. Certainly didn't really have the confidence in them & seemed to lack modulation to them, but this is just a middle of the road hatchback not a high speed GT cruiser or track day special. Then onto the 80-10mph set... WTF happened to the bite? where's the power & what about modulation? At 80mph it I felt like I was gonna run out of runway even though I had over 200m meters to stop. Sure it improved as the speed reduced but it felt like the brakes where on the limit of their ability to stop the car above 50mph. Once I did the cool down process I then went for a 90mph emergency brake test, at high-speed triggering the ABS required some serious pedal pressure.
I voiced my disappointment & said I'd like to look at the brakes again, the owner then took the car for a trip around the airfield & was delighted with the brakes performance said that they'd never worked so well! Thinking I was just spoilt by the Alfa & Exige I borrowed a stock Seicento sporting... sure enough the Sei' was wiping the floor with the Ibiza hauling it's self down from 75mph (I couldn't get it to go faster than that onto the stretch of runway I have access too), sure it didn't have the bite of the Ibiza & you had to be positive with the brake pedal but you were never left in any doubt that this little car was going to stop.
It started me thinking about modern cars, how good are their brakes really?
