Would you mind explaining this a bit more? I'm just curious. I don't drive much, and I find when I do get in a car (hire car, we don't own one) that I find the brakes really vicious to start with - my memory of my mother's car when I drove it regularly more than 10 years ago was that you had to press the pedal quite a way before the brake started to bite, while modern cars you hit the braking point much more quickly. Does that sound like a simple way of saying what you've just said?!
What bit do you want expanded on? I'd break down the performance of brakes into 4 categories:
Bite deals with how the brakes respond when the pad first makes contact with the disc.
Power deals with how easy you can overwhelm the tyre's traction
Progression deals with pedal input to actual braking performance
Modulation deals with how easy it is to control the brake system
With well dimensioned lower pad pressure brakes with little to no servo assistance you get moderate bite, lots of power with liner progression & easy modulation. On a braking system with heavy servo assistance & high pad pressers which delivers the same ultimate braking power you'll get very good to overwhelming bite however progression will be fairly close to an inverse log curve (or if the servo is too small it can wander towards inverse exponential curve! I'd only expect to see this on cars with aftermarket brake kits however) & a reduction in fine control when modulating the brakes.
