Madders
As my learning curve is a vertical line, I thought I would create this thread with a few observations that I have, humorous or otherwise. I will update it as my awareness grows.
On my ten mile commute, giving it the beans saves only three minutes against a more leisurely ride.
Mudguards are a good idea.
A good front light that helps you see where you are going is also a good idea.
Cycling fitness does not help your footballing prowess.
It is advantageous to be cycling behind my fiance'.
If something really is chasing you along a countryside road in the wee hours, it is scary
Try to take EVERYTHING that you need for your day at work rather than leaving it at home, in the wardrobe, or the fridge for example.
