simon.r
Person
- Nottingham
When you tidy up I would suggest a fuse inline with the battery unless you know the battery has one built in, you really do not want to accidentally short one of those babies. A modern car "blade" type works well.
I had the same bottle holder/battery problem, an M5 Rivnut did the job very nicely https://www.cyclechat.net/threads/variation-on-a-nano-conversion.251868/
Add extra rivnuts to the battery bracket. Also you might find the battery holder needs to have some washers under a couple of points. Its not totally flat
I need to do something to secure the battery better, but I don’t like the idea of drilling holes in the frame. I may resort to that, but I’ll see if I can think of another way first (which may involve cable ties). The battery holder came supplied with some spacers shaped to fit the downtube.
Thanks for the comment about the fuse, I’ll look into that My electrical skills are minimal, so will be good to do a bit of research and up my knowledge.
If you remove the cover of the battery base plate (where the connectors are) you will see an aluminum plate. Drill this to secure the battery on the frame. You may also want to put some form of rubber between the frame and plate.
Also, on my bafang installation on a bike with hydraulic brakes, I used one of the supplied vbrakes (the left one) as an 'electric clutch' for when I change gears. It works very well. It also gives the ability to cut power during certain maneuvers.
The one and only fly in the ointment with bafang drives is the way they are programmed. You get too much current even at the min assistance level. It can be changed though. But mine is a 750w so yours may be different. As far as the electric throttle goes, I do use mine, especially when starting from traffic lights until I clip to my pedals and also when offroading technical sections.
Your chainring is too large. The motor can turn it, but not without unecessary stress. Lekkie has produced a 40t model that goes with a bling motor cover that helps it fit with correct chainline. What range cassette do you have?
Still waiting on the electrical connectors to arrive, then I’ll sort the battery position out. Thanks for the point about drilling the base plate, will look into it.
Interesting idea about the ‘clutch’. Again, I’ll look into that. How have you positioned the lever? Any photos?
After a couple of rides I have come to the same conclusion as you about the chainring. I have a 38t ring on order. Cassette is 11/36. Prior to the conversion I had a 36t chainring. This bike’s obviously not designed for speed, so I think the 38t will be OK.
Any decent bike shop could do it.Just by way of an enquiry on a relevant thread, are there any suppliers who will do this type of conversion on your existing bike for you?
