Bar tape?
rickh01
Lincoln
Can anyone shed some light on bar tape, which is the better one lizard skins Dsp 3.2mm or fizik 3mm performance tape . The latter is foam and the dsp is gel tape. Which is the better one
I like Lizardskins 3.2, it is very thick. The Fizik is ok, used before, prefer the LS, looks and feels lush, but it is more expensive (Sigma sport often have at good price). It does wear, depends if the price is a barrier for you
Better probably comes down to personal preference
rickh01
rickh01
Lincoln
Thanks for the advice
Thanks, I've seen somewhere else about white tape, fortunately my bike is dark grey so white wouldn't suit
The grey LS is lush :okay:
mark st1
Plastic Manc
Leafy Berkshire
I've had lizard for the last couple of years but for comfort Specialized bar phat is superior imo. That will be my choice for a re wrap next month.
https://www.sigmasport.co.uk/item/S...gclid=CPfOw9z0kNQCFYcW0wodFzcPVA&gclsrc=aw.ds
freiston
Coventry
I used Cannondale Synapse tape once then replaced it with a cork/gel tape when changing my handlebars. I will definitely switch back to the Synapse next time - it is thick but lovely - and lovely to apply too; it has a grippy strip down the middle of the underside but is not adhesive and it has a bit of stretch to it too - makes it a joy to put on and gives good results. Very comfortable too.
Origamist
That looks really good, I'm going to have a look at it tomorrow . Thanks mark st1
It's good stuff. There are two thicknesses: 4.5mm and 2.5mm. With the gel pads on the former, it means they are super squishy, but come up big. If you want a bit less cushioning and a less wide profile, the 2.5mm version might suffice.
al3xsh
Peak district
I've been using lizard skins (2.5) for a year or so. It feels really nice - padded and grippy - but seems to have an annoying tendancy to unwrap itself. The adhesive bit on the back isn't up to much!
