AndyRM
XOXO
- North Shields
The tape has arrived. In an appropriately sized box...
Simple if it's the waste pipe. Go round to M-i-L's and have a bath thereShould have said, it's the waste pipes that are the issue, the supply seems fine and the sink and toilet present no issues.
I'll post some pictures of the current bane of my life when I get home. And the bath too.
Or just buy a new frickin trap?!? There's nowt wrong with B&Q gear I use it all the time. Take the old one with you and show it to the man. Buy some plumbers mait and refit the plug 'ole since you're in there anyway. Buy a tube of rubber seal lube to make all the seals slip together nicely.
It's so farking easy. If you can do lego you can assemble a bath trap.
Anything else is a bodge. Bodges are ugly, embarrassing and shameful.
....but looking under P for plumbers in Yellow Pages would be a lot cheaperThis will be the best resource for your needs.
Something like, say a garden hose would seep, sort of looks like the tape is sweating - it would eventually cause the sticky crap on the tape to emulsify and leak properly, but that will have a larger pressure behind it.@Piemaster - how much pressure you talking?
May be ok for the bath waste, especially if its only actually got any sort of pressure head (height of the water in the bath above the leak) when you pull the plug out.
Really though - fix it properly. Or find a decent plumber. It'll be cheaper than the damage from the leak.
We have some very awkward pipework under a shower, it's connected up with a length of flexible waste pipe.
