Over The Hill
- Ridden off into the sunset
Battery powered cars have the big problem of charging them up and the limited range of each charge.
Every other battery powered thing I can think of gets over its “range” issue by being able to put new batteries in it, so why not with a car?
I am sure you could have the battery slung under the car or in a big slot and all you do is drive over a fitting machine that swaps the battery automatically for you. Sort of like a drive through burger place.
You would have a contract for using this with the suppler and it is just charged to you.
That sorts out the problems with the battery car. The charging can be done with cheap off peak electricity from hydro or whatever is not being used at night.
Anyone see any problem in this? Why has it not been done?
