Yes I would echo the above; if you can find a Freud Diablo blade in the correct size and number of teeth, this will have far more benefit than the saw itself. My (cheap) table saw came with a very cheap blade and even from new it struggled. I spent £30 on a new Freud Diablo blade and the difference is night and day. Amzaon is awash with various brands of blade for about £15 but IME they're all fairly mediocre unless you're cutting rough wood or are not bothered about chipping out.
If buying a hand held circular saw, I'd either get the bare unit only if you already have batteries for another tool of the same brand, or I'd go with DeWalt which I've found the best quality/price balance. They are also very popular which means lots of choice, lots of availability and a wide range of other tools to use with the one battery. Toolstation for example have just done a good deal on combi drill and multi-tool in the DeWalt range. Also ensure that the guide is accurate and of good quality, as this can be a make or break factor with cutting straight lines
good advice.Yes I would echo the above; if you can find a Freud Diablo blade in the correct size and number of teeth, this will have far more benefit than the saw itself. My (cheap) table saw came with a very cheap blade and even from new it struggled. I spent £30 on a new Freud Diablo blade and the difference is night and day. Amzaon is awash with various brands of blade for about £15 but IME they're all fairly mediocre unless you're cutting rough wood or are not bothered about chipping out.
I'll second the blade discussion, I bought cheap from Amazon, mainly because I couldn't find my odd sized blade anywhere else, bought 2 different ones (20T and 40T from memory) and they were both next to useless from the off. Supposed to be carbide tipped too! Ended up buying a new saw with a more standard sized blade.Yes I would echo the above; if you can find a Freud Diablo blade in the correct size and number of teeth, this will have far more benefit than the saw itself. My (cheap) table saw came with a very cheap blade and even from new it struggled. I spent £30 on a new Freud Diablo blade and the difference is night and day. Amzaon is awash with various brands of blade for about £15 but IME they're all fairly mediocre unless you're cutting rough wood or are not bothered about chipping out.
