Battery service
Gwylan
All at sea⛵
My wife had had her ebike, from new, for over 4 years old and it works hard. Puts a lot of miles in.
The battery has become a bit hormonal recently
Questions about recent changes in range trends and so on meet with little response
Any recommendations for getting it checked and serviced.
I've searched the internet for the battery rating and the bike brand (Go Outdoors)
No real clues so since I know the box will contain a number of cells wired together. So, I'm looking for someone reliable to check it and service as appropriate.
Widnes
WHich motor and battery makes is it?
and how many miles?
Mine is a Bosch and has doen over 10,000 miles and has not dropped mileage much at all
but the previous ebike dropped quite abit over time
I did get it "recelled" but the bloke who did it was getting old and pretty much stopped over lockdown
Anyone else found someone who can do it and is reliable - I have a battery from our folder which needs looking at as well
Gwylan
Gwylan
All at sea⛵
It's a pre lock down bike from GoOutdoors. No idea about, mileage, charges whatever. But at 50km a week over 5 years comes up to more than 10k km.
I'm putting off opening the pack and looking at re-celling myself. But it might come to that.
Drago
The Urban Fringe
Im North of 10k on my Carrera and the battery is as good as ever.
Many of the re cell'ers won't touch batteries with a BMS built in, so you might be in for a bit of an email session.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Assume a newer battery would be better. Technology has moved on over the last 5 years.
Energy density of batteries will have increased between 5-8% per year. But this assumes you can get an appropriate sized modern battery to fit to the bike. If it’s to be certified as safe, I’d imagine thst means a certified third party doing it.
fritz katzenjammer
Der Ubergrosserbudgie
If I were looking at getting a battery serviced I’d be concerned with the origin and quality of the replacement cells. There’s a lot of cheaper cells out there and they can send you down the road to what in the industry is known as a “thermal event”. If I couldn’t get a match for the cell with a known brand name on it, I wouldn’t go there. Also, you don’t want to mix old and new cells, especially if the energy density has changed, that’s just looking for trouble.
If it was my bike I’d get a new battery.
Widnes
I had 2 batteries recelled a long time ago
First time went fine and the recelled battery worked fine but didn;t last as long as a new one - I suspect the cells were not the same quailty
2nd time it just failed after only 2 years - it just stopped working during the winter
Since then I have found that I can get a new battery from a different place for about the same
the place I used has stopped doing it now anyway - I think the bloke that did it was getting on and had health problems over Lockdown so they stopped doing it
But if I want to get our folder working again I will just get a new battery rather than trying to get the old battery working
albion
Gateshead
Battery prices as ever are getting more competitive. So as a xmas refresh I bought a couple of Yose replacement Reention batteries.
Yose has specified EVE 3200 cells so there is little worry about quality. At 474Wh for £144 each(discounted) it will be interesting to see how they perform in comparison to my exisiting Samsung/LG specified batteries.
Bosch, fully proprietary, you pay near triple likely making a good full recell service a better bet. Same for Swytch.
Widnes
Is it even possible to recell a Bosch
I understood that they are so "protected" that it can;t be done
Well - clearly it can - but resetting the firmware/software/thingies cannot be done outside of the part of the factory that makes getting the secrets out of the vaults of MI5 look like ordering a Big Mac
CXRAndy
Lincs
That's why I never bought into the Bosch is so good. They're a nice motor, smooth.
The way they lock them down for replacement and repairs is ridiculous.
I much prefer open software and parts interchangeable options especially with batteries and displays.
TONGSCHENG will allow different capacities and voltages, so you can upside or downsize depending on your needs. Also the smoothness is easily a match for Bosch on the motor.
All you need is a standard 68mm bottom bracket on your bike and away you go
