smutchin
Cat 6 Racer
- The Red Enclave
I'm trying to set up a Bkool Pro trainer to use Zwift on my Macbook Air. I don't have the original ANT+ dongle that came with the trainer so bought a cheap generic one off ebay.
I can get the Bkool Simulator to connect to the trainer but the connection is a bit flaky. Zwift won't recognise the trainer at all - it doesn't get beyond the 'Searching...' stage.
Can anyone recommend a good ANT+ stick to get this working? I understand I need one that's ANT+ FE-C compatible, and it needs to be USB 2.0 (I suspect the problem with the one I've got is that it isn't USB 2.0). DC Rainmaker seems to be a fan of the Suunto one so I might try that.
I think I also need to upgrade the firmware on the trainer (it's the older model) - has anyone had any luck doing this? I'm guessing it should happen automatically via the Simulator but it doesn't appear to be happening and I can't see an option to do it manually. Maybe this is also down to the generic USB stick I'm using. And it seems I can't upgrade to the FE-C protocol until I've done the firmware upgrade either...
