Bianchi Sempre Pro Upgrade
Bald Ealge
Lads, what do you think of the spec on this for £2200? I am looking to upgrade the handlebars and saddle at some stage so I am looking for some suggestions. Anything that you would say definitely needs upgraded?
Bianchi B4P Sempre Pro Ultegra 11Sp Bike Carbon UD Black 2014 Specification:
Frame : SEMPRE, carbon monocoque, bb set PF30, UTSS, compatible mechanical and electronic
Seatpost Clamp : "X Carbon System" 36mm, Black, with Bianchi logo
Headset : Fsa Orbit C-40-ACB ; NO.42/ACB, Sealed 1-1/8 ACB Top, 1.5" ACB Btm (for 46/56mm Head Tubes)
Fork : Full Carbon B4P 28"- 300mm - 1.5" - ss56mm
Top Cap : FSA Alloy top cap, 1 1/8" (28.6mm OD x 21-26.2mm ID)
Shifters : Shimano Ultegra 11 sp ST-6800, ULTEGRA 2sp LEFT, ST-6800, ULTEGRA 11sp RIGHT
Rear Derailleur : Shimano Ultegra 11 sp RD-6800, 11sp , Compatible with low gear 23-28T for double
Front Derailleur : Shimano Veloce Ultegra 11 sp FD-6800 ULTEGRA Double & Rear 11so Brazed-on Type
Crankset : Fsa Gossamer Compact, BB30 System, Forged 6066 arm, ring 3mm Stamped AL7075 , 170-172,5-175mm x 110mmBCD x 50/34t 10sp Compatible N10
Bottom Bracket : included in the crankset the BB-PF-6000/CZ/Di2
Chain : Shimano Ultegra 11 sp, 110 links
Cassette : Shimano Ultegra 11sp 11-28T, 11sp
Brake : FSA Gossamer AL6061, reach 40-50mm
Front Hub : Racing 28H Black Anodized with Alloy QR
Rear Hub : ALLOY 28H black anodized, two sealed bearing,steel body; with QR
Spoke : Inox 2mm - BLACK
Wheelset: Kysrium Elite S
Tyre : Hutchinson Equinox 2 700 x 23, 66TPI, Dual compound
Inner Tube : Kenda 700C Light-weight , 48MM
Stem : Reparto Corse body Alloy 6061, raise -7, UD Carbon wrapped faceplate, height 40mm, 1 1/8"
Handlebar : Reparto Corse Compact, Flat Top, alloy 6061 diam. 31,8mm, reach 126mm, drop 77 mm, black
Tape : La Spirale Ribbon cork + new plug carbon look with Bianchi logo
Seatpost : Reparto Corse Carbon shaft, 2D forged alloy head, 25mm offset, L350 , 31,6mm,
Saddle : San Marco Era Dynamic, carbon steel rail, length/wide 277x135
Bottle Cage : Elite Paron Race composit material
Water Bottle : Elite Bianchi modello Hydra
winjim
I'm not too keen on the Shimano Veloce FD myself ^_^.
Pro Tour Punditry
Change Shimano for Campag. :tongue:
Seriously, FSA chainset's and brakes are crap. So change that - others say they are good, but they are wrong. There's only one reason they are fitted on bikes and that's to save money - why have full Ultegra everywhere else and not on the chainset and brakes? Cost-cutting.
