Bike lights
Red LED flashlight Ultrafire WF-501B, Dealextreme sku 20333 $9.90
Bicycle mount sku 31871 $2.46
3-LED 3-Mode Safety Bike Tail Light sku 35036 $3.54
Lunar 1/2W £9.99 Ebay
Flood-to-Throw Zooming Cree P4-WC 3-Mode LED Bike Light with Mount sku 26800 $12.35
bauldbairn
Falkirk
Good set up - can't say they didn't see you? :thumbsup:
summerdays
Cycling in the sun
Bristol
The light mounted under the seat - is that where the mount is meant to go or have you made some kind of fitting for it...
Nice setup interesting to see an example like that I think I need to ditch my seat post saddle bag because it gets in the way of the light. Need to carry me spare tube and tool kit some where else
Davidc
Somerset UK
That mount for the underseat light looks like the twofish lockblock.
I'm evidently not the only one who's paranoid about being seen at night.
Where did the tool kit in a bottle come from?
tincaman
tincaman
That looks like the one
bottle
But I guess you could use any wide kneck bottle
Yes thats the smaller version, mine came from CR
theloafer
newton aycliffe
you could just use an old drinks bottle cut off the top then cover with a thick plastic cover and an elastic band that what i did cheap as chips :thumbsup:
tincaman
tincaman
Should you have a white light facing rearwards or is it just used as an example??
Yes look like an ordinary white torch but is in fact a very bright red one, see Here
Here are the direct links to all the lights:
Red LED flashlight Ultrafire WF-501B, Dealextreme sku 20333 $9.90, CLICK
Bicycle mount sku 31871 $2.46, CLICK
3-LED 3-Mode Safety Bike Tail Light sku 35036 $3.54, CLICK
Lunar 1/2W £9.99 Ebay, CLICK
Origamist
I'd also consider: 42665 "Brinyte BR01 HA-III CREE XP-E N4 2-Mode 180LM Red LED Flashlight with Strap"
MontyVeda
I fastened the light clip to my saddle bag using two wide washers (1 inside, 1 outside) and a little nut and bolt through a self made hole in the clip. The light is still removable but being secured outside the bag, it's freed up the space it used to occupy inside the bag when the bike was locked up.
