Bike Servicing
Cubist
Still wavin'
Ovver 'thill
Sign the disclaimer first ;). Baby wipes for the discs; hot water and fairy liquid for the pads.
No, no, no. Baby wipes will contaminate the pads.
Buy some Isopropyl alcohol off ebay. Make sure it's 99% though. Spray it on and wipe iit off the rotors, and use a rag and toothbrush on the caliper and pads.
Brandane
Miles cannot be done unless moving!
Ayrshire.
Brandane, which koolstop pads do I need for my tricross? Your link shows a lot of choice, none mentioned cantilevers. Do you still have the extra brake levers on the top of the handlebars. Ta
These are the ones I use. I know it says they are for V brakes, but on my bike they are the same. If you hunt around the web, there are different compounds available, e.g. koolstop salmons which are orange and made of softer rubber. Just depends on your personal preferences.
They fit into the standard pad holders (assuming yours are the same as mine). You just need to pull out the retaining pin, slide out old pads and slide in new ones, then replace retaining pin.
My version of the Tricross didn't have those extra brake levers on the tops of the bars.
Brandane
Ayrshire.
Just wondering, but what is in baby wipes that will contaminate pads? They seem pretty good at shifting oil from chains. I've been using baby wipes on the discs on my MTB without any obvious problems.
oldroadman
Ubique
Because apart from being designed to gently wipe s..t off babys bottomes. they have a bit of skin conditioner in them to stop soreness. Which nicely lubricates things. Enough said! There used to be a spray called Inhibisol - carbon tetrachloride - which was an effectice cleaner and dried everything nicely.
Though about steam? I've seen it used to great effect on mucky components from cars and motos.
