Bealz998
- Norwich,Norfolk
Or just get fit on the bike, it does take sometime, people look for bike fits because of aches and pains, when really most of the time all that is required is time on the bike to improve your overall muscle strength, this will then help support you on the bike.I got same bike and yes they did slap it together. I gave it a FULL service before I even went out for the first time. Haven't really set mine up properly yet. I have raised the seat up so my leg is almost straight when fully extended but not fully locked straight. ( slight bend in the knee )
I did try dropping the handle bars by removing a couple of the spacers for a more aggressive aero approach, but it just gave me bad back ache, so put them back on the highest setting. I do still get the odd back or neck pain so I think I need to get set up properly..... Or improve my posture on the bike ?????
Lots of tips on YouTube, well worth a look
Yes iv read that core strength is also key ? :/Or just get fit on the bike, it does take sometime, people look for bike fits because of aches and pains, when really most of the time all that is required is time on the bike to improve your overall muscle strength, this will then help support you on the bike.
It's key if you believe the multi-billion fitness class craze. Your "core" has no doubt been doing a fine job of supporting you most of your life, nobody has ever explained why taking up cycling suddenly makes it incapable of it's job.Yes iv read that core strength is also key ? :/
Glad you said that as I find it difficult to find the time to go out on a two hour ride these days, let alone trying to find time to do other trainingIt's key if you believe the multi-billion fitness class craze. Your "core" has no doubt been doing a fine job of supporting you most of your life, nobody has ever explained why taking up cycling suddenly makes it incapable of it's job.
Newbies will often find aches and pains, that is relative to any sport not just cycling.
Never said anything about core strength, but the overall improvement in your muscles will improve to support you whilst cycling, which your body at the outset is NOT use to.It's key if you believe the multi-billion fitness class craze. Your "core" has no doubt been doing a fine job of supporting you most of your life, nobody has ever explained why taking up cycling suddenly makes it incapable of it's job.
So rather than get used to something you aren't used to doing, you suggest doing something else you aren't used to doing as it may help you get used to the first thing you aren't used to doing.Never said anything about core strength, but the overall improvement in your muscles will improve to support you whilst cycling, which your body at the outset is NOT use to.
I think you will find that, that is what I suggested. I quote, What I said was "or just get fit on the bike"So rather than get used to something you aren't used to doing, you suggest doing something else you aren't used to doing as it may help you get used to the first thing you aren't used to doing.
What happened to riding a bike to get better at riding a bike?
