Bkool resistance issue
Discussion in 'Virtual Training: Bkool, Zwift, CycleOps & others' started by wimmie, 28 Oct 2017.
  1. wimmie
    wimmie New Member
    Hi anyone experience with following issue on bkool pro?
    As soon the bkool unit is connected by ant+ towards training applications is putting the resistance high like climbing at 10%. Without making an connection there is no resistance.
    Any idea how to solve this?
    Thnx
  2. theboxers
    theboxers TheBoxers on Bkool
    OTC (on the couch)
    Try getting the app up and running first before powering on the trainer. If not mail bkool to get them to dial into the trainer for a reset.
  3. OP
    wimmie
    wimmie New Member
    Thnx for the reply. Contacted bkool they will connect next week to see what's causing it.
    Will update next week.
    Regards,
  4. OP
    wimmie
    wimmie New Member
    Bkool logged in to the unit. And located the issue in empty calibration table. They added the correct numbers and problem should be solved. Will see after real trip the problem stay away.
    Whorty likes this.
  5. Whorty
    Whorty WADA conclude I don't need a TUE!
    SW Wiltshire
    Once you're up and running come and join us in the Cycle Chat Chain Gang leagues. Riders of all abilities to race against :okay:
    Jim Brown likes this.
  6. Aleman
    Aleman Ale Man (BKool)
    Blackpool UK
    Where do I find This Chain Gang League?
  7. Aleman
    Blackpool UK
    Don't bother, found it and requested to join. ... of course my experience of BKOOL Sim will probably end in tears ... as usual ... and nothing to do with being dropped and pootling around at the back ... In my defence,, I have had to put the hybrid on the trainer as I snapped a gear cable on the roadie with no chance to fix it until next Wednesday
    Whorty likes this.
  8. OP
    wimmie
    wimmie New Member
    Thnx for the invitation. Requested to join. :smile:
    Cheers
    Whorty likes this.
  9. Whorty
    SW Wiltshire
    You're in :okay:
    Live races Thursday 7 pm UK time with a re-run 5pm UK time Saturdays. Usually the race is started by @BILL S but best check on the main Team BKool Cycle Chat thread to be sure who will start the race in case Bill is away.
    To join a league race with others, go into the BSIM application and search for Bill (or whoever is starting the race) and join their race. This way you will race live with the rest of us.
    Hope to see you Thursday for stage 3 and good luck :okay:
  10. Barbarama
    Barbarama Regular
    London
    Wimmie, has this fix worked? (I have had the same problem.)
    Dismiss Notice
