BADGER.BRAD
- Shropshire
Hello all,
My son has just been given a GT BMX with the front brake removed and the rear brake not working due to a broken cable. The break in the cable is in the brake lever to giro three way cable which seems as if it has been made as one, is this likely to be the case? I was hoping for a cheap fix as he already has a jump bike. I tried fitting standard v brakes to the missing front brake only to find that the pivot spacing was completely different. I then thought I know I'll take the giro off and put a straight cable all the way through only to realise the rear brake is operated by two cables.
Many thanks for your help
