Bosch Active Line 'clunk'
gbb
Peterborough
My late wife's Motus ebike is now increasingly being used by me...yes its a ladies frame but a large one and im not fussy, despite being a circa 2020 model, its been well looked after and only regularly used for a couple years max.
Personally I dont like mid drive, no sense or feel of the power kicking in etc but when I stop pedalling theres a mildly annoying clunk, backlash somewhere?
Checked the cranks, no play.
Normal or abnormal ?
Widnes
Abnormal - that is the same vintage as mine and there is no clunk
Mine is the lowest version - crossbar and smallest battery - but I think the drive chain is the same
and I would notice a clunk
does it happen more when you are putting more power on the pedals or less?
when mine had loose bolts then the noises only happened when I was putting more power in myself
which did encourage me to learn to ride at higher pedal revs - but it shouldn't happen
  • Like
Reactions: gbb
gbb
gbb
Peterborough
Yes, more force from legs results in a more noticeable clunk when stopping pedalling. Light force from legs, often no clunk at all.
Which bolts were loose on yours ?
Dadam
SW Leeds
Seems strange to me. I can definitely feel it kicking in on my Cube eMTB, in any mode. On Turbo or eMTB modes I have to be careful not to do an unintended wheelie!
  • Like
Reactions: gbb
Widnes
Sorry - no idea
The LBS just said they had tightened them and that fixed it
I went out today and as I was riding along I was thinking about it
There is a very slight thump caused by slight split second overrun from the motor when I stop pedalling
this means the chain spins for a single link or so and then stops
so it is loose when I start again and when the chain ring starts the chain tightens and there is a slight thunk from the chain
I do not think that is what you mean - but I thought it might be worth mentioning
  • Like
Reactions: gbb
Widnes
Is there a video of anything showing this "normal"
problem with "it is normal" is that sometimes other things get classified as part of it when there is actually something wrong on top of the "normal"
gbb
gbb
Peterborough
So after some loose investigating online, it seems a worn chain will exacerbate the problem.
Chain replaced...much better. Not gone entirely, theres just the hint of a clunk now so im happy.
While I was at it I replaced the rear disc pads, braking is quite poor on the back.
Surprised to see...it didnt improve anything so suppose ill have to see how to top up the hydraulic levers. Never played with them before.
