Deleted member 26715
No neither can I but there are other people who claim they know exactly what happened & it was the OP's fault for not checking it before he rode.I cant understand what has happened from the pic...
Ignore everything in the picture other than the bit in the bottom right hand corner. That's the spindle-end of the crank, seen from the frame side of the crank. The curly-wurly bit is the splined crank spindle head that broke off in the matching splines of the crank.I cant understand what has happened from the pic....
Has the spindle snapped and part of it is still in the crank ?
NO.From what I can make out from the picture it seems as though the BB axle shaft has sheared off just where the bolt ends. If that is the case then it would appear to be faulty manufacture.
BB30 type. I took the bike back into the shop and they were able to reattach within 10 minutes. They did not give me an explanation about what they did. I think they felt they may be responsible so they just wanted to fix it and get me out of there.Is that a BB30/PF30 type? The crank is usually held on by a large bolt in the centre. Dud it break or just back out?
That crankset has pinch bolts (just visible in purple) and a retaining cap (in purple) and there is normally a small safety plate between the pinch bolts that engages in a hole in the axle splines (that's on Shimano) - the OP's crank appeared to have a self extracting crank and not have the pinch bolts?Is this any use?
Best advice is usually not to wear pants when you're riding in cycling kit.
Yeah, I should have added more pics. The crank arm flew off.Looks like the ball bearings broke open, too. I went back to the bike shop that did the work and they said that the bearings are inspected, and if they look fine they are wiped clean and reinserted. They were able to add new bearings and reattach the crank arm pretty quickly. I have not been able to ride the bike since the repair due to wrist injury from the fall.I cant understand what has happened from the pic....
