classic33
Leg End Member
That's not Bertie!
No. Because people are idiots and don't possess any common sense. What will actually happen is several vehicles, not just the one or two there is space for, will try to pass a right turning vehicle, resulting in a queue forming in the bus lane around it and blocking both lanes anyway. It's exactly the same reason why cameras are fitted to monitor box junctions.Just sometimes we should try and get the law changed.
For example, driving in a bus lane during operation is likely to result in a ticket if caught. I agree with this, it protects bus passengers, taxis, cyclists etc. (whoever is permitted to use it).
However, I believe that overtaking vehicles turning right should be permitted in bus lanes. And actually a number of councils do build this into the bus lane traffic orders. Hull haven't, and now they're installing bus lane cameras - the result is that you get a road, with two lanes, the left a bus lane, the right a normal lane. A car in the normal lane needs to turn right and can't, so you have nothing in front of it, but nothing can move! Ridiculous, and bad for the environment. If the bus lane was busy, I would say it's fine, as at least that lane is moving and doing what it is designed to do, but I submitted a FOI request and how many buses were expected to use this bus lane in the hours of its operation? 6, in 2.5 hours.
Sometimes a bit of common sense is needed.
I'll assume you're from Hull.
And anyway, why would you want cars in bus lanes? Just peddle past the queues in them smiling.
Yes, enough is enough: I'm fed up with people not keeping junctions clear, and then whining about being fined for doing it....its time people stood up and said enough is enough.
I work just near Castle Street, I cannot not be affected by thisCan't wait for the Castle Street upgrade.
Think of an array of yellow saltires.what is a box junction?
Perhaps a good time to think about cycling! It's only about 4 miles, but provision of decent showers was my concern. In fact, exploiting the bus lanes on Beverley road then the cycle paths along Greenwood avenue, it could be quite a safe, quick journey!
I'll assume you're from Hull. Junction @ Beverley Road / Clough Road. Where I had to sit with a ever increasing queue of traffic behind me for a full cycle of the lights due to the idiots who thought it was ok to block the junction when turning right into Cottingham road. A place where cameras might actually stop it happening.
@Arch has said it. Just don't get hot. In 4 miles it shouldn't be a problem. You'll feel better and save dosh. For me it's a no brainer - especially with the apparent traffic chaos. Just pedal past it all with a grinI work just near Castle Street, I cannot not be affected by this
