Gerry Attrick
Hey, it's true. After some 500 miles of bouncing up and down on my new B17, I can see the faint depressions in the leather caused by me bum bones! Saddle still as comfy as an arm chair.
Bigtwin said:You are blessed. Mine's done at least that, and it's still as hard a iron.
Gerry Attrick said:When I first got it, I applied two good coats of Proofide which a paintbrush on the underside and wiped a thin layer on the top. A week or so later I repeated the process, but left a sixty watt bulb about six inches from the underside to help liquify the dressing and let it soak in for about thirty minutes. That is all I have done apart from ride it.
I wouldn't ever use dubbin - it will make the leather too soft.andym said:I wonder whether anyone has successfully used dubbin to improve the water resistance.
ASC1951 said:What's the problem with using Proofide? My tin that came with the saddle will last at least a decade.
If you want to put something on a Brooks saddle in the rain, try a plastic bag; or your bum.![]()
