Gixxerman
- Market Rasen
My rear tyre lost some pressure so I decided to pump it up using my Halfrauds mini-pump.
This is the first time I have used this pump and it took a bit of experimentation to get it converted from schrader to presta.
Even then it took me some time and a lot of fiddling about to get some air into the tyre. I eventually managed it.
Went into the garage the next day and tyre was completely flat. Strange I thought, must have done something wrong with the valve as it is the first time I have used a presta valve.
Pumped it up again. Next day completely flat again. This was repeated the next day with the same result.
I know that I do not have a p* as it has been up for months.
On closer examination of the valve, it looks like my ham-fisted attempts have bent the top of the valve slightly (the bit that sticks up with the captive nut on it). I suspect that this is the problem.
Some questions:-
1) Could this be the cause of the tyre not staying up?
2) If the valve is goosed, can I fix it in situ? If not, is it easy to change?
3) How do I prevent it happening again? The method I used was to screw the nut all the way to the top then attached the pump. Is this correct?
If it is the correct way of doing it, then it is very difficult to hold the pump steady enough so that the valve is not damaged during the pumping action. What is the correct way to inflate a presta valved tyre?
Some questions:-
