shouldbeinbed
Rollin' along
- Manchester way
Is there a correctly adjusted marker anywhere that I'd need to line up when changing the cable or after disconnecting the linkage to fix a flat?
Yes but which hub; BSR, SRAM or SA?
Oops my mistake sorry.I put SA in the title. Maybe should have done it in the body of the question. Apols.
Ta, luckily I've not needed it yet, just mulling over the difference between the chain pull system and my Alfine and an old dualdrive hub I had, they both seem rather more straightforward for wheel removal and gear setting, but I guess the proof will be in the doing.possibly or maybe not but anyway::
assuming you haven't unscrewed it from the drum (if you have screw it back in again tight and back it off slightly to leave pointing to 3o'clock)
put lever in 3rd and reattach the barrel screw to leave it hangling slightly slack. then check there are 2 defined movements of the chain coming out as you change from 3rd to 2nd to 1st. If you take out all the slack on 2nd then you have over tightened it. Test ride it and fine tune. The freewheel doesn't click in 2nd which is also a handy guide.
more detail on Sheldon brown
http://sheldonbrown.com/sturmey-archer/adj.html
ah ha, makes perfect sense, thanks. I wondered if the hole in the nut had a purpose.Oops my mistake sorry.
Then yes it's easy. Put bike into 2nd, tension monkey chain until the shoulder of the hub pin is level with the axle end, you can see this thru the window of the external nut.
