Kell
- High Wycombe/London
So that's all their lengths... how does that translate to height? i.e. from the ground?
I've not yet come across a diagram that shows each of the stem heights, but if you know the rise of the bars, I guess you can work backwards to find out.
As a consequence these are the about heights of the different stems (not bars):
M (before 2018): 31,5 cm
P: 31,5 cm
M (after 2018): 34,5 cm
S: 37,5 cm
H (before 2018): 37,5 cm
H after 2018: 40,5 cm
For the T-line the world is different again: There are only a M and a S model available - however: Both are using the same stem. So only one type of stem avail. on the T-Line. Did not measure it's height until now as I forgot to do it when I had one in my hands a while ago.
Stem height. Not bar height.
Indeed this information as to my knowledge does not exist. We tried to collect it for quite a while in the former Bromptonauten forum and once we were more or less done Brompton introduced the new stemsThe whole point is that I've never seen anything that on Google or elsewhere that shows the stem heights. Given that the OP was trying to determine what would happen if you put flat bars on an M stem it would be useful information.
If it did exist on Google (in an easily digestible form), I'd imagine that someone would have linked to it in one of the many, many threads about bar heights and bar swaps.
Not forgetting that using S bars apparently limits your front bag options. Not sure why, but that's what Brompton say - !![]()
There was someone on here that had made an S-Type higher with mid riser bars. I was interested in buying the H-type and making it lower - due to the way the stem folded higher up etc and the longer cables, but still couldn't find the information I needed. In the end I took a leap of faith...
As far as I know this is no longer true for a couple of years already. When Brompton invented the S-Stem in 2005 they also invented the S-Bag, that had a somewhat lower frame than the other bags. At that time it was the only bag officially compatible with the S-Brompton. All the others had the larger frame and the plastic grip of that larger frame was endangered to interfere with the steering or catch the cables in the worst case and thus rendering the steering useless.Some tall bags interfere with the low bars making it hard to turn. I have to be careful to have the side pocket covers tied down or they will catch the brake levers as I turn
In practice it was always possible to use the larger bags on the S- model as well with a bit of caution or slight modifications.
However: When Brompton overhauled their bag line two or three years ago they got rid of the plastic grip on the frame and replaced it with some textile handles on the bag. Since then, as far as I know, there are officially no issues with the S-model any more.
Ugh... so does the "M" handlebar have a 120mm rise ? Which in turn means if you were to replace it with a bar with a 30mm rise you would end up at the same height as an "S"? How much farther forward is an "S" than an "M" ?
