Cyclist33
- Warrington
Front: which side of the derailleur cage is it rubbing against? if limiter screw is not helping, try the barrel adjuster at the left hand shifter. turn it a few times then shift down on the front then back up again. might help at least until you can get the cables properly tuned.
rear: which barrel adjuster did you use, the one at the back of the bike or the one on the right hand shifter?
