Should this be necessary for a brand new frame? Or is this when it's needed most? I take your point on the cutters, I use a hefty pair of pliers and clean the ends up after cutting, but gear cables canbe a pig to cut neatly.
Will have a think on the framesaver.
Thanks
Put it this way. Fitting the headset is a faff if you don't have the right tool. And you might also not get the cups in straight. If you are going into the LBS then you might as well get the BB faced and chased so you get a nice clean square face on the BB shell.
The cable cutters are most useful for the cable outers. People do manage without cutters but personally I wouldn't want to cut outers with pliers.
The fact that the frame is 'made' by a British company doesn't mean anything as far as the BB shell width is concerned. It is very likely 68 mm because of the diameter of the seat tube - but it won't hurt to measure it and be sure.
