rh100
Thought I'd post this here rather than in know how as it's touring bike specific.
I've got a reynolds 725 touring frame to build up (Panorama).
When looking for parts for tourers, clearly it's not road gear but more mtb parts. are there any pitfalls when choosing what chainset, mechs etc to buy?
For example, I have a mtb triple chainset I can use, which needs a 110mm bb spindle to get the correct chainline, although sheldon quotes that 'oversize' tubes would need an extra couple of mm, does the panorama have oversize tubes?
Before buying mechs though I need to think about what gear changers I'm going to use, sti levers aren't cheap, I may go for bar end shifters instead, but I need to make sure they are compatible with any mechs I buy, I think the rear mech is less of an issue, but from reading on the web it seems the front is more finicky with chainline issues etc, are bar ends available that have friction on the front and index on the back? As indexing on the front seems more of a hassle and doesn't get changed as often anyway. The chainset I'm thinking of using is Deore square taper and is 22,34,44.
