Buying my first road bike, tips?
RiflemanSmith
London UK
Hi, I will be buying a carbon frame road bike next month.
Are there any tips as I have never had any thing other than a mountain bike, riding and maintanance.
It comes with Tiagra shifters, Presta valves
Get the right size, take your time in the shops getting the right bike (although it sounds like you may have chosen one, although Tiagra and presta valves accounts for a pretty big proportion of road bikes in the shops, 100% if you just consider the valves :whistle: )
Don't drop it or crash it :smile: Be especially wary if it's wet - especially wet white lines and drain covers etc. There are also about a squillion potholes in London's roads so don't ride in the gutter
Buy from a bike shop and it'll get a free check over after 6 weeks / 100 miles
Buy a proper track pump with a gauge
Stop at red lights :whistle:
What else do you think you need to know?
ianwoodi
If you are buying from a bike shop you should get the fitting for free about £95 worth then take it for a test ride i did and it fits me perfectly and is comfortable
RiflemanSmith
RiflemanSmith
London UK
I am used to riding on and off road just not on a roadie.
I have chosen the bike already from an online shop.
Was a bit confused about the shifters but just had a Google, you shift down with the little paddles and up with the levers?
What do you unscrew to use a Presta valve?
Ref the valve, take the cap off and you'll find a little screw at the top of the valve - undo this and put the adapter on and screw it up tight. There should be a video on YouTube. You won't want to be too heavy handed, the valve looks a little fragile
The lever changes gear to make the pedals easier to turn, the lever harder - I never know which is up and which is down :whistle:
Just make sure the bike is the right size - it maybe cheaper online but you don't get help like from a good shop! Make sure you have sent them all the correct measurements. Online you won't get the check over, so you may want to pay an LBS to check all is well after 6 weeks if you are not confident with gears etc yourself
There really isn't much difference riding a roadbike to say a flat bar hybrid on the road, you just hold on a bit differently, brake differently (unless you have cross levers like I do) and change gear differently. No great mystery :whistle:
RiflemanSmith
RiflemanSmith
London UK
What about tyre grip?
I put some Marathon+ on my Hybrid went round a corner on my usual commute, usual speed and lean, was off.
I didn't think tyres would have made a difference on the road, I even thought road tyres would of been more grippy?
What bike is it and what tyres? I've never had a problem myself. Just slow down going round corners especially in the wet
RiflemanSmith
RiflemanSmith
London UK
It was on my Voodoo, I took off my nobblies and put on Schwarbe Marathon+ 700 x 32c, first ride came off.
No, the road bike...folks will be able to tell you if the tyres are any good and what to change to. Will it be an every day commuter or fair weather bike (to avoid the carbon disintegrating in the rain :whistle: )
Spally
When I first started looking for a road bike was looking for carbon frame. Every LBS I went to said the same thing "don't bother will low end carbon bikes". I was looking at spending around £1500 and the advise was to go higher end alloy framed bike.
Spally
What they told us was the entry level carbon frames weren't fully carbon, can't remember exactly what they said it was
