bikeman66
- Isle of Wight
Hi all,
A training plan I am about to start, includes warm-up sessions where, for very short bursts, I am required to pedal at 150+ rpm. Problem is, at the moment I just cannot do it without feeling as though I am going to fall off the saddle. There are longer bursts that require a cadence of 120-130 rpm, which I find I can achieve, if sometimes at the cost of a little technique.
I have tried the 150+, but as soon as I go over about 130, my weight distribution goes out of the window, and with legs spinning that quick I start to bounce on the saddle.
If anyone has any tips as to how I can max out at 150+ without the technical issues cropping up so much I'd like to hear from you. Thanks.
Currently got a 58cm frame with 175mm cranks. Would switching to shorter (165mm) cranks allow me to be smoother, or can anyone please suggest any exercises that could make a difference? Normally ride at a cadence of 85-100.
I presume shorter cranks would reduce this technical shortcoming, but would probably cause certain issues elsewhere.
Any tip gratefully received! Thanks.
