swee'pea99
Having managed to get my crankset 'cap' off, I've removed, cleaned and refitted the crankset, which still now has a distinct 'non-straightness' to it in use (so that it brushes, then doesn't, then brushes the front shifter cage as it rotates). I think I've identified the culprit: play between the crankset and the crank - the square hole doesn't engage snugly with the square crank, so even with the retaining bolt tightened, there's still some play. I was wondering whether I might be able to bodge a tightening by cutting a shim from a Coke can or something. Anyone tried anything like this? Did it work?
