There's something similar doing the rounds in the VW van world.
The motor that controls the heater settings can fail. .....
One guy has twigged it's quicker still to remove the drivers seat (4 bolts) and lay on your back looking up under the dash, making it less than an hour.
But VW dealers want to charge for removing the entire dash because that's the approved factory method from which the book time is derived.
We can be fairly certain someone with some nouse could have fixed that Renfault for a lot, lot less than £1500.
My 944 passed it's MOT today. No advisories.
Always a relief!
Getting an MOT is easier than finding the rattles.
Plenty of those in most Porkers. (previously employed at Clarks of Narborough where the bodyshop was that handled work for Roger Clark Cars, mainly 911's that had gone through hedges backwards)
- but went downhill from there. Firstly, whoever did up the wheel bolts when they fitted the new tyres last July must be built like a flippin' gorilla (cheers KwikFit). It took a 5ft extension pole and more effort than I felt happy exerting to get the bolts undone, even after spraying copious amounts of penetrating oil) and I was seriously concerned about sheering a couple off.
. I need the car in the morning so I fit the new pads onto the old discs - YIKES! TBH, the old discs aren't too badly scored/ridged so 30 miles tomorrow hopefully won't be too bad.
Well, today was really frustrating. It started off okay - the car hadn't been stolen overnight- but went downhill from there. Firstly, whoever did up the wheel bolts when they fitted the new tyres last July must be built like a flippin' gorilla (cheers KwikFit). It took a 5ft extension pole and more effort than I felt happy exerting to get the bolts undone, even after spraying copious amounts of penetrating oil) and I was seriously concerned about sheering a couple off.
Getting the brake piston pushed back took a bit of effort but no real dramas and the outside pads came out easy enough. Ooh, they needed doing with just 1.5mm of friction material left and the wear sensor clearly in contact with the disc but no warning light on the dash. So it's time to remove the slide pins which I'm pretty sure need hex wrench (or socket). Hmm, 6mm too small; 8mm too big; must be 7mm, now where did I put ..... Improvise, adapt and overcome; a T45 fits really well but it's a "T" shape and the brake hose is in the way of the bottom pin. I managed to undo the top pins simply enough but the bottom ones took time as I could only move it 1/6 turn each time. Eventually they are out and the inner pads can be removed - yep, they're down to 1.5mm too.
Time to remove the carrier plate so I can get the disc off. Deja Vu time; not 17mm or 19mm must be 18mm, now where did I put .... No IAO this time; no alternative available. Bummer. I need the car in the morning so I fit the new pads onto the old discs - YIKES! TBH, the old discs aren't too badly scored/ridged so 30 miles tomorrow hopefully won't be too bad.
All reassembled and brakes bedded in. 18mm socket and 7mm hex socket on order for delivery tomorrow so Thursday looks like being another maintenance day. Hopefully the local detailer will be able to fit me in on Friday then I can take some pictures and get the thing on Autotrader. Thinking about it, maybe it would be better if the car was stolen![]()
but I torque the bolts up with a torque wrench.I prefer to see an owner with lots of parts receipts and consistent mot history rather than an alleged fully stamped dealer service. Shows to me a higher level of care.
Hi Pinno718 and thanks for the commentIt may be that the wheel nuts bind and nothing to do with the tyre fitters. It might be down to corrosion and heat generated by the brakes. My local tyre fitters use a torque wrench and so should they all nowadays, there's no excuse. I use a drop of Copper ease for re-assembly. I also have a Dewalt impact dizzybut I torque the bolts up with a torque wrench.
I once had a tyre fitter (this was at a small pace in no-where land after a blow out) bust his Snap On breaker bar on my Sprinter van nuts - they were notorious for binding.
[He moaned a lot and I thought 'you should get a new one under warranty... unless it's hot or second hand'].
The DeWalt (slight tangent] I ordered during lockdown when I was doing the engine transplant/massive mission creep [it's all here > https://forums.tipec.net/viewtopic.php?f=25&t=24357 ]. I was expecting some serious resistance from the rear hub nuts which are supposed to be torqued to 540nm, where people were saying you needed an 18ft extension and a 20 stone bloke as they tended to bind. My nuts came off like butter on the dizzy (assisted by 24h hours soaked in De-Blocker) When revisiting something I had assembled with it, I discovered that the bolts were far too tight and so started researching torque values at the 3 settings on the impact driver. I put the model number in the search bar and... it was the next one up: the 720nm model at the time. So I was sold the wrong wrench. Bargain. It's a priceless bit of kit and makes life so much easier for regular DIYers.
