Drago
- Suburban Poshshire
29 years in the military (many of which were in the REME) taught me some tricks![]()
The Royal Airfix Modellers!
Hi Pinno718 and thanks for the comment
If could be binding but the front wheels, which were removed a week after the rears last year, came undone without any undue effort. Personally I always apply copper grease when putting the bolts back in and also on the face of the hub. I also use a torque wrench which my tame mechanic calibrates for me every year.
Impact dizzies are great for undoing things but I wouldn't use one for tightening anything - I generally use a battery powered drill to spin bolts in so their a bit more than finger tight then finish the job with an open ended/ring spanner (for non-critical nuts/bolts) or a torque wrench. 29 years in the military (many of which were in the REME) taught me some tricks![]()
Rough Engineering Made Easy![]()
Your mob were always good for magically producing a brew from seemingly nowhere.
It taught you to avoid replacing tank tracks![]()
. There is a 'peg' which is turned between 0 and 4 to ensure oncoming vehicle drivers aren't dazzled - setting it at 4 if there are passengers in the rear seats lowers the beam. I was confident it was the switch because when I removed it to examine the part number, I heard the movement motors move briefly. Wiggling the connector and wire couldn't replicate the situation again. As the new switch didn't cure it, I took most of the front bumper fixings off to move the bumper enough to extract the headlight and get to its connector. Multi-meter on the connector proved the circuit was working as required. With the motor/actuator prised apar,t it was possible to manually wind the moving parts to one extreme, and the motor would wind it one way but not the other. So new headlight levelling motors are the next purchase! Oh-the joys of modern motor repairs without the assistance of Haynes manuals of old. Still I count myself lucky it wasn't a wiring loom fault!Just had a letter from Citroën. They just have a recall on their airbags and need replacing. It covers our little C3. Worth doing a Google search to see if other models are affected
I was relieved when our Evri delivery of a replacement headlight levelling switch for our Ford arrived. I quickly fitted it and then became very deflated because it didn't cure the fault. There is a 'peg' which is turned between 0 and 4 to ensure oncoming vehicle drivers aren't dazzled - setting it at 4 if there are passengers in the rear seats lowers the beam. I was confident it was the switch because when I removed it to examine the part number, I heard the movement motors move briefly. Wiggling the connector and wire couldn't replicate the situation again. As the new switch didn't cure it, I took most of the front bumper fixings off to move the bumper enough to extract the headlight and get to its connector. Multi-meter on the connector proved the circuit was working as required. With the motor/actuator prised apar,t it was possible to manually wind the moving parts to one extreme, and the motor would wind it one way but not the other. So new headlight levelling motors are the next purchase! Oh-the joys of modern motor repairs without the assistance of Haynes manuals of old. Still I count myself lucky it wasn't a wiring loom fault!
Is that switch mounted at the rear of the car ? My Mazdas system Is a small 'tie rod' type link between the body and the suspension, I assume connected to a switch, it was all under the rear of the car (no issues with mine, I had to disconnect the link when replacing rear springs)
. She probably wonders why oncoming drivers flash their lights!Just the airbags? 🤣
We are taking this forced layup of a vehicle to go shopping for a newer car
