Car D.I.Y.
Pinno718
Way out West
It's almost a shame to get it all oily again !
I won't see it anyway 🙂 All that work hidden.
icowden
Surrey
Finally I have the chance to participate!
I changed the headlight bulb in the daughter's Fiat 500. Does that count?
If it helps it was an absolute bugger to get out. The electrical header did *not* want to let go of the bulb and as usual the car is designed so there isn't quite enough room for a human hand to get in there without something stabbing into the back of it.
Batteries aren't cheap. Especially stop start. If the one in my van goes, I'll be letting someone else fit it as there is a whole pile of electronic gubbins bolted to it, and it's at the back of the engine bay. They are apparently a 'pig' to replace.
One reason for always turning the ‘stop/start’ off whenever l use my Kodiaq
Pinno718
Way out West
Yep, rarely ever use mine.
New battery fitted this afternoon, Yuasa EFB type. Halfords online were quoting £200 to supply and fit their own unspecified type.
So mine was £134 for a good battery, they're making £55 ish (minimum) to do 10 minutes work !!!
I do tend to opt for Bosch (from a registered supplier) with their 5 year warranty which I exercised when my battery was 4 years and 10 months and got a replacement for free (despite a bit of obfuscation by the seller).
Bristolian
Bristol, UK
...and pray the starter motor doesn't die.
MB do fit a somewhat beefier starter motor to their start/stop vehicles but if it dies it will have lasted more than 194,000 miles so I'll forgive it ^_^
Drago
Drago
The Urban Fringe
My van has a conventional starter motor for normal starting, and a combined alternator-starter for stop-start use. Its a hideously expensive unit so if I can avoid breaking it or wearing it out then all to the good.
Drago
Drago
The Urban Fringe
The stop-start eliminator for mine was common to the Tiguan.
The Chinese seller had a really daft almost random ling name, but the item was spot on and arrived in 10 days. The UK seller sells the same item at a £20 mark up.
Not touched mine. Just leave it on TBH. The system seems smart enough. Press sure it can just be turned off in the menu without it defaulting back on.
