Carbon Fibre?
Moodyman
My bikes to date have been aluminium and Cromo, but my recent bike purchase has a carbon fibre seatpost.
Historically when tightening nuts and bolts, I tighten them until I meet resistance and then turn the bolt half a turn more. This has worked well.
Will this work with CF seatpost or do I need to amend my method. How fragile is CF when tighening bolts?
TheDoctor
Europe Endless
The TerrorVortex
Not terribly IME. As long as you don't tighten it with all your strength you should be OK.
Smokin Joe
Tighten as normal. Believe me, if you have ever undone a bolt tightened to 5nm (which is recommended on most cf seatposts) with a standard Allen key you will know how tight it clamps at that figure.
The important thing is to make sure the edge of the tube and it's clamping slot are free of burrs which may cut through the lacquer.
